How's this OC on air.
Homey D. Clown
I think that's pretty good for a dual core.Crap, I didn't check the voltage though. I have my 3200+ Venice core running at 2.4GHz. So you've got me beat and yours is dual core.Very nice :)
Have you tried going any higher?
Edit: crap your voltage is high. Is it stable and does it run pretty hot? Jeebus. :eek:
whats the temp?
EDIT: i saw temp on the far right. u should elarn to crop ur images.
but nice OC, even though i'd think temp is a bit high for my taste. do u have stock hsf?
I'm running a coolermaster hyper 48 HSF,Temp in room was kinda high and had a couple downloads and windows media running at the same time.This thing is totally stable at this speed, played fear and Far Cry for a couple hours and not one single problem.Haven't tried pushing it any further pretty happy at where it's at for now but I know i'll probably be tempted to try higher.
Try lowering your voltage, that seems way high, excpecially since mine is clocked higher at lower volts.
one might have greater success compared to another overclock it's because of the components used and the steppings of the cpu.
Dasilva, that has nothing to do with an AMD X2 CPU.
Anyways, 2.6 ghz is usually the top end of that CPU so that is a good overclock.
