Hows this look for under $500?
Private_Ops
Games, Web... thats about it.
$500 even
3) Where do you live?
Ohio
4) What exact parts do you need for that budget? CPU, RAM, case, etc. Please be very specific.
CPU, RAM, Case, PSU, HD, Optic
Will be reusing this video card... thats it.
6) Will you be overclocking?
Highly doubt.
19" WS 1440x900 Wide Screen
Here soon.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
Nothing special, a standard MB is fine.
10) Do you already have a legit and reusable/transferable OS key/license?
Yea
Ight, wantin to make an upgrade away from my BE2400 (good CPU none the less) and I've been wanting to try Intel.
So far, this is what I have.
Intel e8400
G.Skill 4GB (2x2GB) DDR2 800
MSI G41M-FD MicroATX motherboard
Samsung SATA DVD Burner
Western Digital Caviar SE 320GB Hard Drive
SeaSonic 80+ 400W PSU
Cheiftec Mesh series mATX case (dead set on this case)
This comes out to $484.44 with S/H.
Gonna use Windows 7 RC 64bit. It looks good to me for basic parts. I can't go over $500, thats my dead set limit. Any suggestions / criticisms?
The stock HSF is fine if you aren't planning to overclock it.
You don't necessarily need a quad-core Phenom II for a gaming machine. You could save yourself some money by going with one of the X3 processors, or even the X2 550.
You should update the BIOS on your board now if you plan on using a Phenom II processor with it.
I think my BIOS is the latest but I'll have to check... I think I may go for the 710 since this board apparently doesn't support the 720 (which I'd rather get... hell even the 2.0 version of my board doesn't support it according to foxconns website.)
Board doesn't support the 550E (sadly) and the 940 seems to be a little more than I need. I may go for it though and call it done.
I know of the issues with AM3 Phenom 2 for your board.
That is why I suggest the P2 940 as it cost the same as the e8400 and fits into the budget, that you posted.
Out of the two though, which is better? I mean the 940 looks better on paper... but, I'm not to familiar with Intel (last Intel I had was a 3GHz P4... so its been a while).
Framerates about about the same generally but the few games that take advantage of the extra 2 cores of the P2 940, easily overpower e8400.
So they're pretty much even?
Are you absolutely sure my board will handle the 940?
Yes I am but still email foxconn for the lastest bios before you install P2 940.
Updated to the latest off the site.
The BIOS update before the latest added AM3 support so I should be good.
