I'm thinking of trying out some extreme OC'ing later this summer. I haven't really sat down and sketched the details out yet, but here's the general idea of what I'm thinking:
Let me start by saying this is NOT a modding project, so I don't care how neat or chaotic the case looks. The whole case will be made of plexiglass/Lexan or something similar, with caulking around the seams to make it airtight. I'll have a Rival VS110 Vacuum Sealer* hooked up to suck out the air, after running some cables through the walls for power, video, keyboards, etc. The drive(s) will be SATA to make routing and sealing easier- I just want to OC as far as I can, so the very fact that it's LN2 tells you how much I care about running anything major on it. I don't even need an optical drive, so long as a hard drive is preinstalled with all the apps I'll need.
Now for the fun part: the three pipes in the pic are filled with LN2, to allow for easy access and some awesome fogging effects.
(I am not volt-modding my video card, so I probably won't use the one on the video card.) I decided to vacuum-seal the case rather than worry about condensation, but then remembered about RAM, MOSFETs, etc. After thinking about it, I ruled out a separate WC loop and instead decided to leave some room for Dry Ice blocks inside the case. Ideally the vacuum would keep it solid indefinitely, but I'm counting on the imperfections of my design, and the warm surface of the case, to sublimate the DI into ultra-cold vapors inside the void. This should be enough for at least an hour of benching, since the vapors will keep the video, RAM, power circuitry, and other ICs cool enough for benchmarking. I should probably mention that a lot of this stuff will need LOTS of cooling:
I'll be running BH-5 with around 4V, maybe a bit more by the time I mod my power supply.
I have three procs to choose from:
One is my Newcastle 3400+, which I've stabilized at 2.7 for now. The mobo is my infamous DFI, which I just replaced thanks to the awesome service at NewEgg. This one will require a DDR Booster, which I already have. If I mod my 5V line to 6V, I can use the Booster to run up to 4.8V or 5V through my RAM, though I don't intend to go anywhere near that high.
The second would be a 939 chip, probably a Venice 3200+. I don't know anything about it yet, since this is the chip I'll get if one my friends buys my current rig. Again, the DFI board- without any doubts or reservations. No Booster here, but again- 5V line modded to 6V if I can.
Last but not least, I'm buying a P-M 1.5 Banias core from someone here on the forums (thanks, Napalm00!) I've got an Asus P4P800 Deluxe, and a CT-479 will run me about $50. I probably will NOT use this rig, because OCZ says the Booster will only take me to 3.4V on this board. Even presuming I mod my PSU, that still won't take me to 4V, and I need to get that high for my RAM to shine. I really want to use my BH-5 for this, since it's the one time I won't have to worry about cooling it.
If you guys see any potential prolems or improvements, please let me know! I'm new to extreme cooling, and I want to make sure this goes without a hitch! I'm putting hundreds of dollars' worth of stuff on the line, so I'd really rather not watch it go up in smoke.
Also, I realized afterwards that the CO2 vapors will probably be enough for my chipset- even presuming a lowly 10x multiplier on my A64, I only need to run a 300HTT. 275 is no problem now, and I'm using the stock DFI heatsink without so much as an extra fan. I probably will dump the LN2 tower for the NB as well.
TIA,
Shaggy
*Sorry, I couldn't find a product page for this product. If anyone else can find it, please post!
Edit:
Oh, sorry- this should have gone under EXTREME Cooling Solutions.
Feel free to relocate if you want, and sorry again.
TIA,
Shaggy
Edit:
