RealMentalCase
- Nov 7, 2004
What do you think of this build ?
I want it for gaming = Crysis / Far Cry2 / COD4 or any other up coming games
I want to try to stick to a $700 budget with shipping included but if it
goes over a few dollars that ok !
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115029
http://www.newegg.com/Product/Product.aspx?Item=N82E16813127031
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130303
http://www.newegg.com/Product/Product.aspx?Item=N82E16820220267
Total = $704.44 Shipping included !
Do you think everything will work together good ?
Can i get away with 2gigs to shave the price down or stick with 4 because i hear theres a problem with Vista seeing 4gigs !
Will the PSU i'm using now (Antec Neo Power 480) be enough power or will i have to pick up one ?
