Hows this Conroe Build? + one question
Conroe E6300, going to OC to like 3.0 ghz
G Skil 2 Gb Ram, 4-4-4-12 timings
MSI X1900XT, i chose this one because theres a 100 $ rebait
WD 250 GB HDD
Coolermaster Centurion w/ sidewindow
Nec Cd drive
MSI 975x motherboard
Antec 550 watt PSU
Also, woud this work? A 250 GB HD and a 80 GB HD? I wanted to take the old harddrive in my old computer and put it onto my new computer. is there a way to use one as like an external hd or like use one as back up or run them in like either raid 0 or raid 1...?
To run Raid 0 or 1, you need the 2 of the same harddrives. You can have multiple HD's in the same computer, no problems, or you can buy a external exclosure and throw the HD in there.
Looks like a nice comp, have fun. :cool:
yeah you can put both HDs in the case. You just cant run them in a RAID configuration. Just install them both and backup your data manually on the 80GB drive. Install the OS, and Apps on the 250GB drive and keep a copy of your personal data on that dive as well. That way you always got a backup of your data.
You can run a RAID 1 configuration with two different hard drives but you will only be able to have as many GB as the smallest drive.
