Hows this build?
dig_em
Good setup?
[939-pin] AMD® Athlon-64 X2 4400+ CPU w/ Hyper Transport Technology
Asus A8N5X nForce4 Chipset w/7.1 Sound, Gb LAN, S-ATA Raid, USB 2.0 PCI-E mobo
2048 MB [1024MB X2] DDR-400 PC3200 Memory Module
nvidia geforce 7900GT 256mb v-card
200 GB HARD DRIVE [Serial-ATA-II, 3Gb, 7200 RPM, 8M Cache]
All opinions welcome, thanks!
Actually, I think i'll go with 4200+. It is $107 less in cost and runs at the same speed just has a smaller cache size(im not planning on OC'ing).
AM2 + DDR2 would be more future-proof, almost no difference in cost.
AMD Athlon 64 X2 Dual-Core Processor 4200+ Socket AM2 (89W) Retail ***Free Shipping***
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=80725-8
ASUS M2N-E Socket AM2 NVIDIA nForce 570 Ultra MCP ATX AMD Motherboard - Retail
http://www.newegg.com/Product/Product.asp?Item=N82E16813131022
OR
BIOSTAR TFORCE 550 Socket AM2 NVIDIA nForce 550 MCP ATX AMD Motherboard - Retail ;)
http://www.newegg.com/Product/Product.asp?Item=N82E16813138026
Corsair PC26400C5 2Gb (2x1GB) DDR2 Memory -
http://www.newegg.com/Product/Product.asp?Item=N82E16820145590
You could also get cheaper 667 memory and run it at 800.
Ah crap, my mistake...I already ordered it and I didn't get the newer stuff. In a month or two my family is getting another PC and it was going to be intel duo 2 core technology, so think I'll be fine? As long as I have one computer with the new tech?
Also, will i notice this computer I ordered run any slower compared to if it were the AM2 cpu and DDR2 memory? Please say no :(
Don't worry about it man, the upgrades/benefits the AM2 platform will see aren't coming for a while. The issue is that the lower wattage cpus and (soon to be) less expensive DDR2 RAM aren't available to you, but thats not a big deal.
The platforms are essentially equivalents in speed at the moment (a 939 4200 will run just as quick as an AM2), so don't fret.
yep, negligible speed difference, just more upgradable since they don't make 939 CPUs anymore. With a Core 2 Duo system around, you'll have some DDR2 to play with, so I wouldn't worry about it.
But why make a thread asking if it's good if you already paid for it? Not that it's a bad setup. What power supply did you get and what brand is the memory?
