Hows the 3600+ X2 OC'ing?
TheToE!
[H] Brewmaster
The price just keeps dropping! Whats the general consensus on the OC'ability of these chips?
Very good overclocking for the money. TeamStrykerCore has his over 3ghz. I have mine at 2.533 on stock volts (The TForce mobo likes to overvolt a little) with a Arctic Cooling Freezer 64 pro. Others are somewhere in between. If you are looking for a cheap dual core setup, go for it.
i'm at 2.8 on 1.3v.. but the asus m2n board is flaky. What are your temps? You know there is a sticky for this in the amd processors section.
what's a fair comparison for an overclocked brisbane in regards to a c2d? e4300? obviously in cpu speed tests the c2d will fair a whole lot better, but in real world performance as in games, would the difference matter much?
i hit 3ghz on a 3600 but it wasn't too stable, however it was at stock volts and on one of the t-force 550s with an AC Freezer 64 too. I'm thinking of getting the same setup for an upgrade to pci-e if vs just getting an a8n32-sli deluxe. kind of sore about it being a downgrade but i can't hit 2.7 stable on my 4200+ even with a bit of extra juice.
