Originally posted by mewannafastpc
if it runs faster than it looks good, but if it runs faster but not as stable then it looks bad
you are not running at the rated speeds of your ram so i wouldn't say that the ram is unstable it maybe your cpu
Originally posted by Chams
What do these timings stand for, I've always seen people use them with no explanation. (Googles)... In the meanwhile I want an explanation!.
i thought you had BH-5 chips on your kingston, but if you checked the kingston website and they said that your rated timings are 2-3-3-7 then i wouldn't go under that it'll make your ram unstable. and try lowering the voltage too, only overvolt if you are overclocking.
Originally posted by Glow
I am overclocking though. My ram really doesn't seem unstable at all actually why do people say to change ram to 2,2,2,7 then? With this ram what should my max fsb be around?
im sorry if im making this confusing but yes 2-2-2-7 would mean faster performance, but that is only for chips that are designed for such tight timings, i think yours is unstable so don't run it at that anymore, and unless you're running 217 fsb you're not overclocking your ram yet
I umderstand that say 12x192 basically 2300MHZ with my ram running at 1:1 would what would my ram be at 5:4? I don't understand that.
last time I got it to 195 it got unstable.
2.5 3 3 (7)<<if i change that to 11 will it make it run betterOriginally posted by m³ñ
I don't agree. If the RAM can take it and be stable, then use tighter timings.
The timings, 2 2 2 7, are how often the RAM 'refreshes', in a sence. By lowering the first three numbers, you make it refresh faster. The last number is slightly differnt. Lower is generally better for it, but for some reason, NForce2 mainboards like 11 better. There is apparently a bug in the chipset design.
I have some RAM that is being overclocked quite a bit. I have the voltage up, as well. This RAM is crap. I have it running 2.5 3 3 11 at 200 fsb, which is under it's rated timings (3 4 4 9) and way over it's rated speed. It does just fine. In fact, it gets some outstanding benchmarks, and I'm quite pleased with it. I had this RAM running 2 2 2 11 at it's rated speed, as well.They are mis-matched, brand wise, and running in dual channell.
I find my ram doesn't like running at 11, I don't know why but I have to reset my cmos when I change it.
I have an nforce2 board but last time I set it to 11 I had to reset my CMOS but now it's at 7
