Hows it looking so far?
smf080
This is my first build so bear with me. This computer will only be used for games and burning music/dvds and watching movies. This is the parts list i have so far. I wasnt sure how much RAM I needed and I need help puting together a cooling system.
Case: Lian Li PC-V2000B - http://www.newegg.com/Product/Product.asp?item=N82E16811112074
CPU: AMD Athlon 64 X2 4400+ Toledo 1GHz FSB Socket 939 Dual Core Processor - http://www.newegg.com/Product/Product.asp?item=N82E16819103546
RAM: CORSAIR XMS 1GB (2 x 512MB) 184-Pin DDR SDRAM Dual Channel Kit System Memory - http://www.newegg.com/Product/Product.asp?item=N82E16820145450
Power supply: Antec TRUEPOWERII TPII-550 550W - http://www.newegg.com/Product/Product.asp?item=N82E16817103931
Mobo: ASUS A8N32-SLI Deluxe ATX AMD Motherboard - http://www.newegg.com/Product/Product.asp?item=N82E16813131568
Video cards: 2x BFG Tech Geforce 7800GTX 256MB 256-bit GDDR3 VIVO PCI Express x16 - http://www.newegg.com/Product/Product.asp?item=N82E16814143043
Hard drive: Western Digital Caviar SE16 WD2500KS 250GB 7200 RPM 16MB Cache SATA 3.0Gb/s Hard Drive - http://www.newegg.com/Product/Product.asp?item=N82E16822144701
CD/dvd burner: PLEXTOR Black IDE DVD Burner Model PX-740A/SW-BL - http://www.newegg.com/Product/Product.asp?item=N82E16827131357
CD/dvd rom: SONY Black IDE DVD-ROM Drive Model DDU1615/B2s - http://www.newegg.com/Product/Product.asp?item=N82E16827101131
sound card: Creative Sound Blaster X-Fi XtremeMusic Sound Card - http://www.newegg.com/Product/Product.asp?item=N82E16829102188
tv tuner: KWORLD VS-LTV7131R(RF W/FM) TV Tuner Card - http://www.newegg.com/Product/Product.asp?item=N82E16815100129
operating system: Microsoft Windows XP Professional With Service Pack 2 - http://www.newegg.com/Product/Product.asp?Item=N82E16837116195
Hows it look? I need help on the cooling system.
thanks
Axman said:
Why go dual GTX with crap ram like that?
In fact, why go dual GTX? If money is no object, or less an object, get one GTX512 now and one later.
I like the Redlines a little better but I can't find any reasonably priced:
http://www.newegg.com/Product/Product.asp?Item=N82E16820146397
I agree, you should get 2gb of ram instread but het axman i think he wants his to upgrade before 2008. Its almost impossible to find the 512 mb card
I would want fan cooled. Its already about at its $$ limit. With what i posted it was like close to 2600 or so. I would like to keep the price under 3000 but the cheaper the better.
Maybe i should drop the dual gtx's and go with a single X1900XTX? And upgrade the ram. Would the motherboard i picked work with X1900XTX?
You could just drop the GTXs and go with two GTs.
I personally wouldn't pay so much for a processor (that's why I got my 3700+. I plan to upgrade down the road to a X2), but more power to you.
Looks good, have fun. :)
