How Your Console Could Testify Against You
HardOCP News
[H] News
If you are ever accused of a crime (or planning on committing one), you should probably know that your video game console can testify for / against you. :eek:
"For example, if someone is trying to prove that Suspect A was running an attack against a World of Warcraft server, there will be logs to indicate that fact within World of Warcraft," he explained. "Or if someone wants to defend themselves, they can say, 'whoa Mr. Investigator...check those logs, I was playing Team Fortress 2 at the time.' Keep in mind too, that logs are just a small piece of a very large pie. If an investigator wants to get a good idea as to the activities conducted on a system, this information is very important."
In reality something this can only be used against you. I know, it isn't fair, but if it helps the prosecution's case to allow it to be entered into evidence then it will be, if it hurts their case then it will be dismissed as 'maybe it wasn't really you there'.
Just like this video says: http://www.youtube.com/watch?v=i8z7NC5sgik
Anything you say CAN be used against you. Not for you, but against you. If it helps the prosecution then it's valid and they believe you're telling the truth, if it hurts the prosecution then anything you say is simply hearsay and will be dismissed.
You are incorrect. While the prosecutor won't use it to help you, your attorney can. That's the point of the adversarial system. Your attorney will use things to try and create reasonable doubt.
The statement police give you means that they'll turn over anything you say to the prosecution, and that the prosecution will use the parts of it that is useful to their case. It does not mean that your attorney isn't allowed to introduce their own evidence to the contrary.
Simple time stamps will add a lot to a case. Doesn't have to be on a video game.
Well that video is an actual attorney saying the opposite. If it hurts you it's admitted, but if it helps you it's challenged by the prosecution and in almost all cases will be thrown out as hearsay.
