How would you build this serious SQL server?
ZROUT
I know what I want, but I'm not exactly sure how I will put it together yet. I have limited experience with several different RAID setups in the same system.
I would need a dual xeon box with 12 hard drives split into these categories.
RAID 1 for OS and applications - 2 drives
RAID 1 for SQL database log files - 2 disks
RAID 5 for SQL data files - 4 disks
RAID 1 for temporary db - 2 disks
RAID 0 for SQL backups - 2 disks
would I need 3 different raid controller cards? what hardware would fit the specs? how about general thoughts on this setup... like/dislike?
thanks
I would recomend a external system that has its own raid controllers. It will be more reliable and easier to setup and upgrade.
Something like this
http://products.gateway.com/products/gconfig/prodseries.asp?seg=cp&gcseries=gtwy840
That box is actually made by www.nstor.com you should be able to find it cheaper some where else.
I would recomend keepping the OS and applications on a single scsi disk inside the server. Everything else in an outside enclosure. Make the temporary DB a raid0, and make the SQL back ups a raid5. That would be a very good performance and reliablity setup.
If this is a serious server consider the following:
RAID 10 for SQL database log files - 4 disks
RAID 10 for SQL data files - 4 disks
RAID 1 for SQL backups - 2 disks
Though you could have the OS and the Temporary share the same drives, and even the backups too if you have the space.. But I am assuming this is just for maintanence backups.. you actual data backups for disaster recovery will be off site on another media right?
RAID 10 is the fastest for Databases, and you want your DB and Log files to be fast...
You could also use RAID5 for the other three (esp if they are going to share drives). so:
RAID 5 for OS,temporary db,SQL backups and applications - 3 drives (or 4 if you want hot spare)
==>Lazn
Off of the Microsoft web site, they suggest splitting the volumes like this:
Vol1: OS
Vol2: MSSQL Programs + system databases
Vol3: Application db data file(s)
Vol4: Application db log file(s)
In your case, add:
Vol5: SQL backups.
Use Raid-1 and RAID-10 as above.
A good, quick resource on SQL server setups:
http://www.sql-server-performance.com/sql_server_setup.asp
