How would you build a $300 computer?
dejacky
My sister needs a desktop computer before New Years, so this limits me to buying parts from computer stores and local Dallas, Texas resellers like (Frys, Microcenter, CompUSA, etc). It will be used for listening to music, web browsing, office tasks, and occasionally playing games like Starcraft; nothing "super graphics" intensive but multitasking friendly. If you had a budget of $300 (or less not including tax) and needed the following features, what parts (and from where) would you use?
wireless lan capability
Dial-up modem
Good sound quality (preferably one that doesn't make speakers pop when computer turns off)
Wireless mouse
Keyboard
DVD/cdrw combo drive
Hard drive (as much space as budget permits)
Quiet and Stable
Honestly, I would just go with an OEM if I were you. A (legal) copy of XP will set you back about $100 anyway.
Your best bet is a Fry's combo/deal, since dell raised their prices. I think the cheapest dell is $350 now. If you can find XP Home for $30AR or if you already have an xp license to use, then go with a fry's combo. They usually have a Pent. D 805 combo for $90 (mobo + CPU), a FAR Ultra ATX case, a FAR Ultra V-Series 500W PSU, onboard video, and 1GB of ram for $90. Check the Fry's ad tomorrow (Friday!!!). Oh, and a HDD should run you about $50AR, just search the deal sites. And an optical drive should be about $30 for a 16x dvd burner.
$0 - Ultra V Series 500W Power Supply ($40 - $40MIR)
$0 - Ultra Wizard Blue Mid ATX Tower Case ($40 - $40MIR)
You could also try Dell Outlet.
With that tight of a budget, you are going to be really working on the edge. For a keyboard/mouse, you are probably going to have to be a bit creative and or go super duper cheap. You really can't afford good sound quality, you'll have to go with the onboard solution. About a year ago I built some web servers using that Frys sempron/mobo deal for about $230 each, which had almost all the functionality you wanted save wireless and the burner which wouldn't have cost too much extra. I'll just post some ideas.
$30 Burner - http://www.newegg.com/Product/Product.asp?Item=N82E16827106042
$47 LGA775 Celeron 326 2.53Ghz http://www.newegg.com/Product/Product.asp?Item=N82E16819112207
$50 Asus P5S800-VM Onboard Video/Audio/NIC - http://www.newegg.com/Product/Product.asp?Item=N82E16813131521
$44 Seagate 7200.9 80gb IDE - http://www.newegg.com/Product/Product.asp?Item=N82E16822148095
$20 Linksys wireless adapter ? http://www.newegg.com/Product/Product.asp?Item=N82E16833117205
$10 Generic Modem?
That leaves $100 for a case/powersupply/mouse/keyboard. I dunno if all that stuff is compatible, but it should at least give you an idea of what you could get new. Get whatever combo deals you can to save on costs.
Barebone kit 90.00;
http://www.newegg.com/Product/Product.asp?Item=N82E16856110031
processor 48.00:
http://www.newegg.com/Product/Product.asp?Item=N82E16819112205
hard drive 45.00:
http://www.newegg.com/Product/Product.asp?Item=N82E16822145126
ram 2X256 53.00
http://www.newegg.com/Product/Product.asp?Item=N82E16820141213
dvd burner 30.00
http://www.newegg.com/Product/Product.asp?Item=N82E16827152076
key/mouse 35.00
http://www.newegg.com/Product/Product.asp?Item=N82E16826105035
Total 301.00 + ~25.00 shipping. This is the best to do for 300.00
And if you don't need the ram, you could get the wireless/modem or etc...
I built a cheapo AM2 sempron, with a foxconn board, 512 ram, a dvd burner and an 80 gig drive, for 250. I had a spare psu and case. It was very fast for the $250.
I tried doing it with the cheapest parts.
Asus 800Mhz VIA barebones
Dvd burner
160GB hard drive
cheapest LCD on newegg
crappy $9.99 keyboard
$2.99 mouse
two of these cheapo 256MB sticks
windows xp home (hope you have a copy of 98 or 95 laying around)
479 plus shipping. Unless I seriously missed something, it doesnt get cheaper than this. Probably could save 5-10 dollars by finding a $9.00 case, a returned motherboard and a low end sempron... maybe maybe not.
Might be best off getting a used system, that Via C3 I selected has about as much power as a 486sx.
I was pushin for fry's because they usually have good combo deals and you said you were going to buy the stuff locally (since you need it before new yrs). Whatever you do, if you get an GQ/e-machine, swap out the PSU with that FAR model (Ultra 500w). I've had to replace several e-machine PSUs and Mobos (PSU kills mobo), that were 2+ yrs old. E-Machines uses refurb'd parts, so the quality isnt that great.
What do you all think of that Fry's mobo/cpu combo for ~$159 (ECS mobo with dual core amd cpu)?
Good luck on ECS.
I recommend seeing what customers are holding in their hands at the Fry's return desk before making an error of that magnitude.
Second the Dell recommendation. Can't be beat for budget computing with an everything-you-need package.
With ECS from Fry's, its a gamble. But since you're on a budget and you need it from a B&M store before New Years, then I'm afraid ECS is your cheapest solution if you don't need an XP License.
http://ads.ocregister.com/interactive-ads/ocr/images/pdf/20061229095129.pdf
$90 - COMBO: Pentium D 805 (oem; bare cpu) + ECS P4M800Pro-M v2 (onboard video/audio/lan)
$20 - Thermaltake TR2 M21 RX Socket 775 Cooler
$70 - 200GB Maxtor SATA300 7200RPM 8MB Cache (No rebate)
$90 - 1GB Corsair ValueSelect DDR400 PC3200 (single stick)
$0 - Ultra Wizard ATX Case ($40 - $40MIR)
$0 - Ultra V-Series 500W PSU ($40 - $40MIR)
$270 + tax and shipping (after rebates)
See if you can find an optical drive for cheap, hehe. Not sure if you have the same specials in TX, but good luck!
That setup makes me cry just thinking about using it... lol. That's not an insult to you though
But notice, that doesn't have a keyboard, mouse (he even wants wireless, more $), operating system, optical drives, dial up modem (he wants one), wireless NIC (he wants one) or speakers.
Now a bargain basement dell will come with all this except a modem, wireless NIC, or wireless peripherals. It will also have a full warranty, full support, and be the same price as if you were to include everything you actually needed.
Also, you don't list a monitor. Dells have monitors, and often printers.
I stand by the Dell, even if it makes me sob a little bit to say it.
Dell... I mentioned that already, lol. But he said he needs it before new years and he wants to get it all at a local B&M. The HD in that build above is expensive... if you can find a cheaper HD for about $40, that leaves room for all the other things I left out. I only mentioned stuff that was in the Fry's ad, lol, hence the link to the fry's ad before the list of parts. Again, Dell is a better deal, but since you need it immediately, try a GQ or e-machine (or some other generic brand build from one of the stores).
I don't need any Operating System since I already have WinXP. Will that frys pentium D 805 setup work with an Enlight 300watt ATX 2.03 power supply? damtheman was kind enough to hand me his old system, so im hoping to use some of these components:
tbird amd cpu (not sure what speed)
mobo: asus a7a266
memory: uses ddr1 or 133 but currently has 3x256 133 sticks
hdds: 2x ide i think os is 40, and extra is 80gb
videocard: some generic vga
CDRW for optical
thank you all for your input...good brainstorming :cool:
$30 - CoolerMaster Socket 775 Cooler
$90 - 1GB PNY 667mhz DDR2 memory
PowerSpec MicroATX aluminum case ($19.99 from microcenter)
Raidmax Hybrid Series 400watt power supply
1.44 floppy drive
Samsung DVD-rw/cdrw combo drive
The computer is either freezing or giving me the following errors during Windows XP Installation. Any help from those of you more experienced folks would be much appreciated!
Here are the errors I'm getting:
Blue screen: some problem with this file --> mdwmdmsp.dll
Fatal Error
c:\windows\setuperr.log
"The signature for WindowsXP Professional Upgrade is invalid. The error code is 6ba. The RPC server is unavailable"
*Page_Fault_In_NonPaged_Area*
The blue screen and error message could be a ram problem,maybe try with another stick if you have one available to see if it is the ram that is the problem.
I have a Kingston 533mhz DDR2 512MB dimm and a PNY 1gb 667mhz DDR2 dimm. I've tried both memory chips separately and I still cannot install windows XP. Any ideas? :confused:
It really sounds like a memory issue. Try a different cable for the hdd and optical drive. Did you try both ram slots? Do you have any DDR ram you could try it with?
