Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
How would you do what? That picture doesn't do anything to clarify your question, really. You want to know how to create UV lighting effects? Flourescent gel pens work wonders. Do a simple search and you should be able to find info on it.
no, i don't think its UV lighting effects, cuz its blue and the white stands out...or maybe i'm wrong...sorry for not clarifying...the circuit-board-looking design, what would i need/use to get something that looks like that?
it looks like a piece of plexi with the circuit board design etched in and lighted with some led's, or it could be a uv reactive piece of plexi with some extra uv paint in the etch to make it stand out
That would take some mad etching skills.
At first I thought that was a motherboard/circuit board with the lines traced out in uv, but that looks like a piece of acrylic instead. The lines could be etched or just traced with some white uv paint and drawn on there. There is a lot of potential for that design.
