i was referencing my 4 ghz 3.2e prescott, 250 mhz fsb and of course i will be overclocking would 2.4 ghz on water cooling and the dfi sli mobo be pushing my luck on a 3800 X2?Earp said:I'd say a 4GHz prescott would have a edge on the 3800 X2 in gaming, depending on exactly which prescott. Of course, that's assuming the 3800 X2 is at stock speeds. I wasn't aware there was a stock 4GHz prescott, so if you're overclocking the prescott, you could overclock the X2 as well, which would probably push it ahead in games.
Of course, I haven't seen any direct comparisions, so I'm just extrapolating based on relative bench scores.
The X2 is better at multitasking, though I'm not sure what issues you're talking about. Remember though, if you have two apps that are both heavily accessing files on the same hard disk, even 4 cores aren't going to make a difference.
i did not say i wasnt going to oc it i want 2.4 ghz minimum if water cooling can get me thereincomudro said:I think for it to be fair tou would def have to OC the x2 3800 and that would own the intel IMHO
so my psus prob no problem and i can multitask with few issues? i didnt do a64 cuz more tasks you do performance goes down real fast compared to what HT doesEarp said:My 3800 X2 is clocked at [email protected](I think thats the voltage) on a Abit AN8-Ultra. It's watercooled with a MCW6002 block. I could go higher, but I'm not sure if I want to push the voltage any higher.
My powersupply is a NeoPower 480w, and that is powering the X2 and a 7800GT. Also, I can encode MPEG4 while playing HL2 with no problems (although the priority on the encoder is set to low).
so your saying a64 x2 3800+ at ~2.4 ghz is about the same as a 4 ghz prescott and not worth the money?Earp said:I'm not sure you'd see a lot of an increase in speed, but as long as your power supply has the 24-pin connector, it should be fine.
ryuji said:so your saying a64 x2 3800+ at ~2.4 ghz is about the same as a 4 ghz prescott and not worth the money?
there is no better video card i can buy and my mobos caps are bleeding from being stressed so much at 1.6v my psu wasnt powerful enough to keep the 12v power stable, the caps got extra stress, there leaking now(were talking about 150-160 watts of power consumption here, my whole computer consumes 400 watts measured from 120v outlet)Earp said:4GHz is a lot of CPU to use. I doubt you'd see more than a 10-20% performance increase (just pulling that number out of my a$$). If it were me, I'd spend the $350 on a big 21in display or a better video card, and be a lot happier.
Now the upgrade from my 2500+ bartron & 5600FX was a significant performance increase...
RAPING?Sir-Fragalot said:I was nearly at 4GHz on my Pentium 4 [email protected] and in benchmark testing and actual game benches using time demos,. the Athlon 64 3200 was about even with me, and the Athlon 3500+ was RAPING my machine. Same amount of ram, same video card. I had Raptors and the whole works. That's what prompted me to go AMD in the first place.
EnderW said:
Elios said:.......... id say it would do 3.0 on water easly with good ram
what SHOULD i expect my max3's death sentence draws near, maybe another week or two, damn leaking capsozziegn said:not hardly....
3GHz is ALOT to ask for from an X2 3800+ chip. doesnt matter what kind of cooling thats behind it. now, I'm not saying it isnt impossible to get an X2 3800+ up to 3GHz, I'm just saying that it doesnt happen too often.
you should expect 2.4GHz with the right equipment and hope for 2.8GHzryuji said:what SHOULD i expect my max3's death sentence draws near, maybe another week or two, damn leaking caps
