How will this water cooling setup perform? I'm gonna do water cooling on an e6600 in my TJ09 case and I'm gonna get the following parts:
My e6600 is at 3.4ghz @ 1.39375v. I'm currently using a Zalman 9500 and get 42 C Idle/70 C load (orthos on both cores)
D-Tek FuZion cpu water block
AquaXtreme 50z pump
2x BIP 120.1 rads
2x Yate Loon fans 47 cfm/28dba i think (should i go higher cfm and/or 4 fans instead of 2?)
Tanky Bay reservoir clear
Coolant? (what do you think?)
AquaXtreme 50z pump
2x BIP 120.1 rads
