Hi Guys!
I have been using a "D.Vine 5" case for my Desktop Workstation for the last 10 years (+/- 1 year), but the top have never been on and the MediaDisplay never connected - I want to change that for my new build...
If possible, I'll actually do 2 almost identical builds (same basic case): A Desktop Workstation & A MediaCenter, so here are my thoughts:
1) I'll keep the design as basic, clean & symmetric as possible - I personally prefer that design.
2) The case will be made out of 6 "plates"/"profiles" like the "D.Vine 5" is, so it will be easy to change the design based on use (but I'll try to make it "MultiUse").
3) It will be designed to house radiators for water-cooling - I was thinking (maybe not thermo-optimal, but...) 2-3x 120mm rad's in the front. The reason to use 2-3x 120mm rads and not 1x 360 rad is to keep the design symmetrical and the 2. (mid-mounted) rad can be left out if you want the case to be a MediaCenter with a LCD-Display, BluRay-Drive & HDD's
Now to the difficult part - How to source & get the parts!
I'm sure ProtoCase can machine the 6 profiles for me, but where do I source the front USB-panel, power & reset buttons with circle lights, remote-receiver panel/window, MediaCenter ColorLCD-pannel and get the back-plate (Card & I/O frame) made!?
I'm in EU and own a company with Im/ex-port rights, though I prefer EU-suppliers (less paperwork)...
Do any of you have any info and/or comments, please let me know! Thank you all very much in advance!!!
