How to...
Fox_T
Sorry for asking a noob question, but how to (take)post screenshots of stuff like cpuz, etc... without using digicam(its ****ed at the moment, i sat on it now the lens wont comeout...), what kind of software do I need? thx
use the print screen button for full desktop copy and alt + print screen copy just for the active window. then paste in mspaint, save
Hit print screen, and then open paint and select paste, and your screenshot will appear. If your using Vista, you can use the snipping tool as well. Alt and print screen will capture the active window only.. Then use ImageShack or something similar to host the image so you can copy it into a post here.. Hope that helps.
And not a noob question either... I think there are alot of folks that have no idea how to do this..
Thanks a bunch! seems pretty straighforward.:p Itll help me alot with ocing.
Yeah, once uploaded, there should be some code easily marked for "forums" "thumbnails" etc.
What resolution should i use, tried 19"-1280x1024 after ~30secs broweser saz page can not be displayed
Don't select "resize image". When you've put the file path into the box, leave the 2 tick-boxes unticked and click on "host it!"
