http://hardforum.com/showthread.php?t=1091998w1retap said:I'd also like to know... lol. Why would you go from USB mini to a 25-pin serial?
jpmkm, where's the other thread?
For what?ValeX said:If anyone finds a wiring diagram, post it.
Well there is no "wiring diagram" for that. That's why I've been trying to figure out what the hell the OP is trying to do. rs232 and usb are completely different protocols; you cannot simply connect them passively. There has to be some electronics in there to bridge the protocols. When USB is involved, there must be a host device. With USB->rs232 converters(to hook an rs232 device up to a USB port), the computer is the host. If you want an rs232->USB converter(to hook a USB device up to an rs232 port, which I believe is what the OP is requesting), then you need to have a USB host in there somewhere. The USB host would talk to the USB device, and then talk to the rs232 port on the computer. This is complex and expensive. And I still don't understand why anyone would need to do such a thing.ValeX said:To wire a USB to a serial plug? (read: title of thread)
yes.. that is correct. I linked him to this, http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=320018510239&category=3704 but he doesn't want it. Its pretty much impossible otherwise. If he got that usb-->serial adapter, all he would need is the USB-->USBmini.TheMostWantedPolishTwin said:I don't think you can just wire usb to rs232.. those converters need drivers as they work as a virtual com port...
