dye4metal said:wat? how else are u supposed to do all this. i just want to wipe it out. i tryed reformating thats it??? tell me how i can wipe it out
Would you change a flat tire while driving the car? Don't take this the wrong way, but if you've never done this before, call a friend that has done this, and ask them to oversee.dye4metal said:wat? how else are u supposed to do all this. i just want to wipe it out. i tryed reformating thats it??? tell me how i can wipe it out
djnes said:Would you change a flat tire while driving the car? Don't take this the wrong way, but if you've never done this before, call a friend that has done this, and ask them to oversee.
gtjr_ph said:boot with winxp cd
remove partition
make new partion
format to ntfs or fat 32
proceed to installation
