how to videos
Why would you need videos? They're all very straight-foward. I was able to do both with nothing more than having the tools placed in front of me.
For lights it's about as easy as installing RAM, if not easier. Just use two-sided tape to attach them to wherever you want in the case.
For sleeving, use a molex remover to pop the little plastic molex connectors off, slide sleeving over the wires (Slide on some heatshrink too, if you want it) and then put the molex connectors back on.
Combine them and you have the skills you're looking for :)
