How to use WDTLER utility
tonih
I purchased two 1 TB WD cavair black sata drives to put in a thecus NAS and set up as a Raid 1. I know I need to enable TLER, but I'm not sure how. I've created a bootable CD with the utility and have attached a drive using a USB to SATA cable to my laptop, but my drive is not getting recognized when the utility menu comes up to enable TLER. Am I doing something incorrectly or is there another way I can enable TLER?
Thanks
Because I didn't know what TLER meant:
http://en.wikipedia.org/wiki/TLER said:
Time-Limited Error Recovery (TLER) is a name used by Western Digital for a hard drive feature that allows improved error handling in a RAID environment. In some cases, there is a conflict as to whether error handling should be undertaken by the hard drive or by the RAID controller, which leads to drives being marked as unusable and significant performance degradation, when this could otherwise have been avoided. Similar technologies are called Error Recovery Control (ERC), used by competitor Seagate, and Command Completion Time Limit (CCTL), used by Samsung and Hitachi.
