How to use VIVO (Simple Question)
roninblade
Well deciced to give VIVO a try just hooked up my N64 to it, but how do u capture it, wat software i need? THanks a Bunch
The best software I found was NeroVision Express if you are wanting to transfer the image through your graphics card. I wouldn't though for the following reason:-
I spent a long time searching the internet for programmes that might let me do what you are looking to do (although I wanted to connect my XBOX), the video capture software in the programmes I found didn't produce an acceptable image on my monitor, even when I lowered *from* the native res *which on my monitor is 1280x1024* to 800x600 *(although I could perhaps have gained better results had my monitor allowed me to display 640x480)*. The image produced was blurry at best.
The general consensus is that if you want to connect your console to your PC, the best piece of hardware you can do it with is a TV Tuner and plug directly into the back of there. Beware though that you probably won't want to play it full screen as the native res of your monitor is gonna be way more than the res of your tv that you are used to playing your N64 on. The only way to do it would be to alter *from* the native res (alot of messing around) of your monitor *to a lower res* or run the game in windowed mode for the best visual quality.
Although if someone has found a decent piece of software that has good quality picture capture running through VIVO then I still might be interested in linking my XBOX up???
*EDIT* Apparently I made a mistake so thought it appropriate to correct myself for the benefit of the viewing public. I humbly apologise and hope that the world can someday forgive me.
A) You can't change the native res of a monitor.
B) SDTV has 480 vertical lines. Maybe 640x480 would have worked better
i use to use my Ps2 on my Winfast TV tuner , worked pretty good (cheap card for 35$).. just full screen like everyone has said looked like ass @ 1600x1200 :p but windowed mode was great , chrisp image an there was no real delay on it...
A. Ooooh, I made a mistake while typing... Sue me. You know damn well what I was trying to say. What I should have said perhaps was alter the resolution from that of your native ie: 1280x1024, down to such and such resolution.
B. My monitor doesn't support 640x480 hence that wasn't an option for me. My monitor suppports resolutions of 800x600, 1024x768, 1152x864, 1280x720, 1280x768, 1280x960 and its native res of 1280x1024 FYI. Before you speak you should really have checked out what my monitor supported.
Calm down man, he was just trying to help.
If I over-reacted I apologise, it just seemed to me that he was being 'smart' deconstucting what I typed. Fair enough, i made an error perhaps typing and only stating native res as opposed to also adding that the original poster might have to try a supported res. I just see so many people on here that deconstruct every last word someone says be it in error or otherwise, trying to get a 'oneupmanship' over someone else by correcting every last thing, which just seems petty. I may be wrong.
Try the freeware app DScaler. http://www.dscaler.org/ It has plenty of settings so you should be able to tweak it for a good quality image. Start by having it change your monitor's resolution in full screen to 640x480. (Source, I'm certain that your monitor will display images lower than 800x600. You get the splash screen when windows boots right? IIRC that's 512x384, WinXP limits the desktop resoluiton to 800x600 and above. Try loading a game and setting the res to 640x480. If it doesn't work I'll buy you a beer, you just have to come to CA to get it. :p With your monitor you're going to lose quality in anything other than 1280x1024 though, one of the reasons I like my 100 pound dinosaur...)
DScaler doesn't play nice with saving video to the hard drive, so don't do it. Use AVI_IO instead. http://www.nct.ch/multimedia/avi_io/index.html AVI_IO is cool, not as many video options as DScaler, but it locks the audio to the video. I've had sync issues capturing video with other apps.
And to round out my vid capture software, I hang on to Virtualdub. http://www.virtualdub.org/index I tend to use it only for converting video though.
Good luck,
-dB
In the past, I've used VirtualDub but you can also use MS Movie Maker...
You also have to download the WMD driver for your vivo to work, appearently its not just enabled when you install the video card drivers.
