how to use langouste behind a proxy
I was wondering how do you use langouste behind a proxy? Since we're setting the proxy to 127.0.0.1 in client.cfg, is there a langouste config to set the internet proxy?
I've got some code here that allows Langouste to be "stacked" on another proxy but it's not yet release-ready. I will let you know the moment it is...
Transparent proxy would work.
I hope to make a release on weekend.
Ok, documentation is still to be updated but go ahead and check this out:
http://darkswarm.org/langouste3/langouste3-15.10-pre1.tar.gz
To use external proxy add -X proxyaddress:port to command line.
If you omit :port portion, Langouste will use port 8080.
Setup is the usual: untar / make / sudo make install.
Let know if you have any questions or run into issues.
Have everything setup but can't reach the stanford servers because I believe they're doing a server move today. Will update once i'm able to get some assignments.
Also, some proxy require username and passwords but I don't see how to specify that from the documentation. Is this possible with this build?
tear, are there any major differences between 15.10pre1 vs the final 15.10 on the proxy feature? Just wondering if I need to update to the latest.
Good point up there... proxy authentication is not implemented. Though when there's interest
I will go about adding it.
And no, you shouldn't need to update from pre1 to final 15.10 unless you really really want
to as there are no functional changes in Langouste code.
I've been seeing these sent errors after completing every WU for a while now. It'll try 3 times, then go on to the next WU. While working on the new WU, another transfer will be initiated and sometimes it'll be successful and sometimes it'll error out and be removed from the queue. Are there langouste logs I can send you tear?
Code:
[17:58:36] Completed 247500 out of 250000 steps  (99%)
[18:02:00] - Autosending finished units... [September 8 18:02:00 UTC]
[18:02:00] Trying to send all finished work units
[18:02:00] + No unsent completed units remaining.
[18:02:00] - Autosend completed
[18:09:21] Completed 250000 out of 250000 steps  (100%)
[18:09:33] DynamicWrapper: Finished Work Unit: sleep=10000
[18:09:43]
[18:09:43] Finished Work Unit:
[18:09:43] - Reading up to 64340496 from "work/wudata_08.trr": Read 64340496
[18:09:44] trr file hash check passed.
[18:09:44] - Reading up to 31555804 from "work/wudata_08.xtc": Read 31555804
[18:09:44] xtc file hash check passed.
[18:09:44] edr file hash check passed.
[18:09:44] logfile size: 191393
[18:09:44] Leaving Run
[18:09:49] - Writing 96248569 bytes of core data to disk...
[18:10:13] Done: 96248057 -> 91510513 (compressed to 5.8 percent)
[18:10:13]   ... Done.
[18:10:13] - Shutting down core
[18:10:13]
[18:10:13] Folding@home Core Shutdown: FINISHED_UNIT
[18:10:13] CoreStatus = 64 (100)
[18:10:13] Unit 8 finished with 81 percent of time to deadline remaining.
[18:10:13] Updated performance fraction: 0.825933
[18:10:13] Sending work to server
[18:10:13] Project: 8101 (Run 1, Clone 4, Gen 319)
[18:10:13] + Attempting to send results [September 8 18:10:13 UTC]
[18:10:13] - Reading file work/wuresults_08.dat from core
[18:10:14]   (Read 91511025 bytes from disk)
[18:10:14] Connecting to http://128.143.231.201:8080/
[18:10:14] - Couldn't send HTTP request to server
[18:10:14] + Could not connect to Work Server (results)
[18:10:14]     (128.143.231.201:8080)
[18:10:14] + Retrying using alternative port
[18:10:14] Connecting to http://128.143.231.201:80/
[18:10:14]     (128.143.231.201:80)
[18:10:14] - Error: Could not transmit unit 08 (completed September 8) to work server.
[18:10:14] - 1 failed uploads of this unit.
[18:10:14]   Keeping unit 08 in queue.
[18:10:14] Trying to send all finished work units
[18:10:14] Project: 8101 (Run 1, Clone 4, Gen 319)
[18:10:14] + Attempting to send results [September 8 18:10:14 UTC]
[18:10:14] - Reading file work/wuresults_08.dat from core
[18:10:14] - 2 failed uploads of this unit.
[18:10:14] Connecting to http://128.143.199.97:8080/
[18:10:14]     (128.143.199.97:8080)
[18:10:14] Connecting to http://128.143.199.97:80/
[18:10:14]     (128.143.199.97:80)
[18:10:14]   Could not transmit unit 08 to Collection server; keeping in queue.
[18:10:14] + Sent 0 of 1 completed units to the server
[18:10:14] - Preparing to get new work unit...
[18:10:14] Cleaning up work directory
[18:10:14] + Attempting to get work packet
[18:10:14] Passkey found
[18:10:14] - Will indicate memory of 32171 MB
[18:10:14] - Connecting to assignment server
[18:10:14] Connecting to http://assign.stanford.edu:8080/
[18:10:14] Posted data.
[18:10:14] Initial: 8F80; - Successful: assigned to (128.143.231.201).
[18:10:14] + News From Folding@Home: Welcome to Folding@Home
[18:10:14] Loaded queue successfully.
[18:10:14] Sent data
[18:10:21] Posted data.
[18:10:21] Initial: 0000; - Receiving payload (expected size: 30306164)
[18:10:52] - Downloaded at ~954 kB/s
[18:10:52] - Averaged speed for that direction ~832 kB/s
[18:10:52] + Received work.
[18:10:52] Trying to send all finished work units
[18:10:52] Project: 8101 (Run 1, Clone 4, Gen 319)
[18:10:52] + Attempting to send results [September 8 18:10:52 UTC]
[18:10:52] - Reading file work/wuresults_08.dat from core
[18:10:52]   (Read 91511025 bytes from disk)
[18:10:52] Connecting to http://128.143.231.201:8080/
[18:10:53] - Couldn't send HTTP request to server
[18:10:53] + Could not connect to Work Server (results)
[18:10:53]     (128.143.231.201:8080)
[18:10:53] + Retrying using alternative port
[18:10:53] Connecting to http://128.143.231.201:80/
[18:10:53]     (128.143.231.201:80)
[18:10:53] - Error: Could not transmit unit 08 (completed September 8) to work server.
[18:10:53] - 3 failed uploads of this unit.
[18:10:53] + Attempting to send results [September 8 18:10:53 UTC]
[18:10:53] - Reading file work/wuresults_08.dat from core
[18:10:53]   (Read 91511025 bytes from disk)
[18:10:53] Connecting to http://128.143.199.97:8080/
[18:10:53]     (128.143.199.97:8080)
[18:10:53] Connecting to http://128.143.199.97:80/
[18:10:53]     (128.143.199.97:80)
[18:10:53]   Could not transmit unit 08 to Collection server; keeping in queue.
[18:10:53] + Sent 0 of 1 completed units to the server
[18:10:53] + Closed connections
[18:10:53]
[18:10:53] + Processing work unit
[18:10:53] Core required: FahCore_a5.exe
[18:10:53] Core found.
[18:10:53] Working on queue slot 09 [September 8 18:10:53 UTC]
[18:10:53] + Working ...
[18:10:53] - Calling './FahCore_a5.exe -dir work/ -nice 19 -suffix 09 -np 64 -checkpoint 15 -verbose -lifeline 2607 -version 634'
[18:10:53]
[18:10:53] *------------------------------*
[18:10:53] Folding@Home Gromacs SMP Core
[18:10:53] Version 2.27 (Thu Feb 10 09:46:40 PST 2011)
[18:10:53]
[18:10:53] Preparing to commence simulation
[18:10:53] - Looking at optimizations...
[18:10:53] - Created dyn
[18:10:53] - Files status OK
[18:10:56] - Expanded 30305652 -> 33158020 (decompressed 109.4 percent)
[18:10:56] Called DecompressByteArray: compressed_data_size=30305652 data_size=33158020, decompressed_data_size=33158020 diff=0
[18:10:56] - Digital signature verified
[18:10:56]
[18:10:56] Project: 8101 (Run 3, Clone 1, Gen 349)
[18:10:56]
[18:10:56] Assembly optimizations on if available.
[18:10:56] Entering M.D.
[18:11:03] Mapping NT from 64 to 64
[18:11:09] Completed 0 out of 250000 steps  (0%)
[18:22:18] Completed 2500 out of 250000 steps  (1%)
[18:33:14] Completed 5000 out of 250000 steps  (2%)
[18:44:08] Completed 7500 out of 250000 steps  (3%)
[18:55:00] Completed 10000 out of 250000 steps  (4%)
[19:05:55] Completed 12500 out of 250000 steps  (5%)
[19:16:50] Completed 15000 out of 250000 steps  (6%)
[19:27:46] Completed 17500 out of 250000 steps  (7%)
[19:38:39] Completed 20000 out of 250000 steps  (8%)
[19:49:36] Completed 22500 out of 250000 steps  (9%)
[20:00:34] Completed 25000 out of 250000 steps  (10%)
[20:11:30] Completed 27500 out of 250000 steps  (11%)
[20:22:23] Completed 30000 out of 250000 steps  (12%)
[20:33:20] Completed 32500 out of 250000 steps  (13%)
[20:44:16] Completed 35000 out of 250000 steps  (14%)
[20:55:09] Completed 37500 out of 250000 steps  (15%)
[21:06:07] Completed 40000 out of 250000 steps  (16%)
[21:17:04] Completed 42500 out of 250000 steps  (17%)
[21:28:00] Completed 45000 out of 250000 steps  (18%)
[21:38:54] Completed 47500 out of 250000 steps  (19%)
[21:49:50] Completed 50000 out of 250000 steps  (20%)
[22:00:46] Completed 52500 out of 250000 steps  (21%)
[22:11:44] Completed 55000 out of 250000 steps  (22%)
[22:22:38] Completed 57500 out of 250000 steps  (23%)
[22:33:33] Completed 60000 out of 250000 steps  (24%)
[22:44:29] Completed 62500 out of 250000 steps  (25%)
[22:55:22] Completed 65000 out of 250000 steps  (26%)
[23:06:18] Completed 67500 out of 250000 steps  (27%)
[23:17:13] Completed 70000 out of 250000 steps  (28%)
[23:28:08] Completed 72500 out of 250000 steps  (29%)
[23:39:01] Completed 75000 out of 250000 steps  (30%)
[23:49:57] Completed 77500 out of 250000 steps  (31%)
[00:00:53] Completed 80000 out of 250000 steps  (32%)
[00:02:00] - Autosending finished units... [September 9 00:02:00 UTC]
[00:02:00] Trying to send all finished work units
[00:02:00] Project: 8101 (Run 1, Clone 4, Gen 319)
[00:02:00] - Error: Could not get length of results file work/wuresults_08.dat
[00:02:00] - Error: Could not read unit 08 file. Removing from queue.
[00:02:00] + Sent 0 of 1 completed units to the server
[00:02:00] - Autosend completed
[00:11:49] Completed 82500 out of 250000 steps  (33%)
[00:22:40] Completed 85000 out of 250000 steps  (34%)
[00:33:33] Completed 87500 out of 250000 steps  (35%)
[00:44:27] Completed 90000 out of 250000 steps  (36%)
[00:55:19] Completed 92500 out of 250000 steps  (37%)
[01:06:12] Completed 95000 out of 250000 steps  (38%)
[01:17:05] Completed 97500 out of 250000 steps  (39%)
[01:27:59] Completed 100000 out of 250000 steps  (40%)
[01:38:52] Completed 102500 out of 250000 steps  (41%)
[01:49:48] Completed 105000 out of 250000 steps  (42%)
[02:00:43] Completed 107500 out of 250000 steps  (43%)
[02:11:40] Completed 110000 out of 250000 steps  (44%)
[02:22:33] Completed 112500 out of 250000 steps  (45%)
[02:33:29] Completed 115000 out of 250000 steps  (46%)
[02:44:23] Completed 117500 out of 250000 steps  (47%)
[02:55:16] Completed 120000 out of 250000 steps  (48%)
[03:06:10] Completed 122500 out of 250000 steps  (49%)
[03:17:04] Completed 125000 out of 250000 steps  (50%)
[03:27:58] Completed 127500 out of 250000 steps  (51%)
[03:38:51] Completed 130000 out of 250000 steps  (52%)
[03:49:45] Completed 132500 out of 250000 steps  (53%)
[04:00:41] Completed 135000 out of 250000 steps  (54%)
[04:11:35] Completed 137500 out of 250000 steps  (55%)
[04:22:29] Completed 140000 out of 250000 steps  (56%)
[04:33:24] Completed 142500 out of 250000 steps  (57%)
[04:44:20] Completed 145000 out of 250000 steps  (58%)
[04:55:13] Completed 147500 out of 250000 steps  (59%)
[05:06:10] Completed 150000 out of 250000 steps  (60%)
[05:17:07] Completed 152500 out of 250000 steps  (61%)
[05:28:03] Completed 155000 out of 250000 steps  (62%)
[05:38:56] Completed 157500 out of 250000 steps  (63%)
[05:49:53] Completed 160000 out of 250000 steps  (64%)
[06:00:49] Completed 162500 out of 250000 steps  (65%)
[06:02:00] - Autosending finished units... [September 9 06:02:00 UTC]
[06:02:00] Trying to send all finished work units
[06:02:00] + No unsent completed units remaining.
[06:02:00] - Autosend completed
[06:11:46] Completed 165000 out of 250000 steps  (66%)
Aye.
And to answer your log location question -- w/15.10 it's /dev/shm/langouste-$USER
note that they are not persistent logs - they go away in an event of reboot.
