I've added a wireless router to my home 10/100 network, and I'm having trouble getting it to work the way I'd like. Really, what I needed was a wireless Access Point - but I got a deal on a wireless router, and really it should be able to function as an access point (I hope) if I leave the WAN port unused.
Here's what I've set up. My home network works flawlessly using an SMC 10/100 router (my cable modem is connect to its WAN port). The router is at the very corner of the house. This is connected via crossover (through a long path in the ventilation ducts) to the new wireless router, in another (centrally located) room. The two routers are connected via their LAN (not WAN) ports, because I'd like all my PCs to be on the same level - as if they were all connected to the same switch.
There are two PCs connected (with wires of course) to the old SMC router. The old router is the gateway, and the new (wireless) one shouldn't attempt to be the gateway, because there's no internet connection on its WAN port. However, with my laptop being assigned by DHCP, it will attempt to use the new wireless router as its gateway, and will of course fail.
I would like to avoid using the wireless router as the gateway because my cable modem must be in that room in the corner of the house. I'd like to place my wireless router in the center of the house so that my coverage is best inside the house, rather than on my lawn.
I could configure the laptop with a static gateway, to lead it to the IP of my old wired router. This works, I've tried it. However, when I'm at the university (there's several networks there, so I need to use "automatic" network settings), I'll have to reconfigure my network settings just to connect over there - that's sort of a pain when done twice per day. The Windows XP Alternate Network configuration isn't a solution, because the first choice must be "automatic." In this case, the computer will automatically (and successfully) find my home network (and I can file transfer to my other PCs) but I don't get internet access because the gateway doesn't work. So since it can connect to the network (but not the internet), Windows won't bother using my alternative [static] network settings.
So really I'd like to find a way to configure my wireless router to pass on all internet requests to my wired router. Then I can set my laptop to use "automatic" for everything. The problem is, I don't know what router settings to use.
My router is a TRENDnet TEW-431BRP and has the following settings under the "routing" page:
RIP:
Enable Routing Information Protocol V1 [checkbox]
Static Routing:
Destination Network: ___ . ___ . ___ . ___
Network Mask: ___ . ___ . ___ . ___
Gateway IP Address: ___ . ___ . ___ . ___
Metric: _
My current network IP addresses are as follows:
SMC router: 192.168.2.1
Wireless router: 192.168.2.99
PCs: 192.168.2.101....192.168.2.254
Thanks for reading. Any help would be GREATLY appreciated. Thanks so much.
RIP:
Static Routing:
Metric: _
