How to turn Internal into Ext
Rydawg5143
Want to turn my internal 3.5 1TB WD drive into an external and plug it into my wireless router. Whats the most cost effective route to do this?
So could I use this with my 1tb drive and plug it into my Router and access it from each computer?
Yup, that can work. Note that you're paying a wee bit more for USB 3.0 which most routers don't have (but if yours does, by all means).
I have a 32GB USB flash drive hooked up to mine. Basically turned it into my own personal cloud storage. :D
Thanks for the info Solid, Maybe a 64 GB flash drive would work for what I want and at same cost. Will look into that!
I paid 20€ for a basic no name USB3 enclosure. It works well but there is no fan, I cut into the sides to allow more air but it's still not great. I would not use a dock for a permanent install, a dock is put on your desk and allows to plug a collection of hard drives.
