How to tell for bleed?
eLus1ve
I'm wondering how I can tell if my 226BW has any bleeding effect to it... Also what is the most fast and effective way to calibrate my monitor? Or should I just use the premade settings?
Select blank for a screen saver, turn off all the lights and if you have bleed, you will see bright light coming from the top, bottom or corners.
there is a eizo program that will help, i just can't fond the link right now
Thanks a lot. I really didn't do any adjusting other than some minor contrast adjusting.
