How to tell bad CPU
phatjedi
I bought a FX55. Installed it in my A8N32 replacing a Opteron 150. Buttoned everything back up, green light on Motherboard, no post. Zilch nothing. Pulled Video card out and tested it on second machine. Works, Tried CPU in another board. Nothing. So my conclusion is I have a bad processor. Put the old processor back in, and same thing nothing. Unplugged everything, pulled battery out, reset CMOS, everything. Just had video card and and one hard drive and DVD drive. Still nothing. Green light did come on though.
Did I just kill 2 processors, or did the bad processo kill motherboard. I have built several systems in the past, and never had anything like this happen. Any help is much appreciated.
If you put the 150 back in and it didn't power up... it's possible the board got cooked. On that "other" system you tried the FX55 in, after it wouldn't boot, did you put the original CPU back in... did it start?
Best bet would be to pull everything out of the case (the A8N32) and try starting the system outside the case (using just Mobo, CPU, Ram & Video). While the mobo is out.... look for scorching or burned spots on the PCB. Also check the capacitors for any signs of bulging.
Best of Luck!
Thank you for the input guys, I will check the board for burn marks and try it outside of the case. Also to answer the other question, I put the Opteron back into A8n32 and nothing. I am getting the sick feeling I just toasted 2 mother boards and 1 processor.
Toasted 2 motherboards? What happened with the other one? I think we really need to know the results of testing both processors in both motherboards.
That same thing has happened to me many times and very rarely is it blown equipment. Usually it's stupid stuff you'd never think of and rebuilding the computer is the only way to really check everything.
If there is something blown, it seems like it has more to do with changing hardware than the chip itself.
I really hope it is something stupid I did. I have built several computers in the past succesfully with no problems. I tried both processors in both motherboards, green light, but no post. I double checked all wires and only had one hard drive, video card connected. RAM is fine. and both video cards are working. I will give it another try and post results. Thanks again for everyone's help.
It is confirmed, I am an idiot. I simply had the power switch on the wrong prong. I am very happy though, I really thought I fried my motherboard and my new FX-55.
I appreciate all the input everyone's input. I guess this goes to show you no matter how many PC's you build, you still have to be very methodical ( at least I do) in what you are doing.
:D
:D
Amen to that!
You will always make those occasional silly mistakes, dont worry everyone does. Glad it wasnt your hardware.
I appreciate the thought. Just felt like an idiot earlier. My wife got a good laugh out of it. :)
