How to speed up mouse???
ANDRADE
Help!
I just bought thermaltake Keyboard and Mouse (Xaser III). Everything works alright, it's just that the mouse is very slow. Mouse options on Control Panel don't seem to do the trick all the way.
My monitor is 17" lcd screen and using 1280*1024 resolution.
I know there are some registry tweaks to speed up mouse, i just haven't found any.
Can anybody help me with this?
Any help would be greatly appreciated.
First thing your going to want to do is overclock that mouse. :)
I don't have that particular mouse, but often times now, there are drivers that you need to install. Thermaltake's website's not working for me at the moment, but i'd check if they had drivers available.
Hmmm...odd, i checked the Thermaltake site this morning and i couldn't find any drivers at all, i just checked it again after your suggestion, and oddly enough there was a newer driver available.
I downloaded it installed it and mouse is working perfectly now.
Thermaltake's site might be having some problems.
THANKS
