How to solve USB Device Descriptor Failed error?
Zepher
[H]ipster Replacement
I have an Apple Superdrive and it was working with Windows 10 before the Anniversary Update and I tried using it this morning and got a couple of errors, Code 43 when it was listed as unknown USB device, and now a Code 10 with the driver loaded.
Both errors had Device Descriptor Failed.
I actually got it working. After messing with it for an hour or so, I decided to just plug the drive into my front USB ports instead of the Plugable 7 Port USB3 hub and Windows saw the drive and it worked.
Not sure what the deal is, as the drive worked through the hub before.
Was worried that I would end up with a $25 paperweight, since all my machines have the latest Windows 10 on them.
