Easiest and best way to do it is:
1: Boot windows, open disk manager (Start > Right click Computer > Manage > Disk Management), right click your windows partition and then click shrink volume. Shrink your NTFS volume to whatever size (Windows will show you the minimum, usually 5GB above what you are using).
2: Boot OS X. Use disk utility to expand your HFS+ partition into the empty space.
Worked for me.
