JoeOnePack
- May 18, 2012
I am trying to figure out how to run my loop and incorporate the motherboard ports into the equation. Here is something I drew up. Any suggestions?
Looks good. Just bleed it at full-speed if the pump is variable (after you do leak testing), otherwise it'll take forever to get the "glug glug" sound out.
Tsumi, correct me if I'm wrong....I think it would be a lot more efficient with the front radiator inlet/outlet at the top rather than the bottom....with the inlet/outlet at the bottom you are sure to have air trapped at the top not to mention making the pump work harder to pump the water up rather than letting gravity help with the flow.
also, dont you want the reservoir bleed as the highest point in the system?
just my .02
Better, although I would get rid of the res altogether: in that configuration any small air bubble that i collects will be immediately sucked back into the system (defeats the purpose). In general I think reservoirs are superfluous and dangerous - they really only help with filling and bleeding (which you do once) and the rest of the time they're a big risk for leaks/damage. That said, if you do plan to use the res, outlet goes parallel to or below the inlet, not above.Well I won't rule out switching the front radiator. I just drew up a loop to represent the front radiator facing up. What do you think?
Btw, what case is that? Looks like you have a lot of room.![]()
Yessir. Pump is variable. What setting should I run the pump on for leak testing?
just my .02
Water is heavier than air, you will never be able to "push"air down ,as it will always be at the highest point in the system, which is why putting the inlet/outlet at the bottom is just an invitation for a trapped air pocket which will reduce the efficiency of that radiator an amount equal to the surface area of the air pocket.You're going to end up with air pockets either way. You'll either have the air pocket on the inlet that needs to be pushed down to the bottom of the radiator and then back up again, or the air pocket at the top that needs to be pushed down to the outlet.
This is the reason that closed loop cooling systems in which the radiator is not the highest point are always equipped with a bleeder that is located at the highest point.
I wouldn't waste my time putting in a drain. When are you going to drain your loop? Why?Whichever way I decide to run my front rad (decision will be made in next couple days), how do you guys think I should run a drain?
I was thinking of running a Koolance QD on the lower GPU, but I don't think you can actually drain from these fittings. It's a shame because it would have been a perfect setup.
just my .02
I'd recommend strongly considering dumping the MOSFET blocks as 1) they don't do anything and 2) they severely restrict flow. With two full cover GPU blocks and a CPU block there's already a lot of resistance in that loop, adding the MOSFET block might really make your temps suffer. This is especially true if you're trying to pump up to the CPU block through the two fullcover blocks (which may already give sub-optimal performance).
Ahh man... Why tell me this now.. lol
If I don't dump the MOSFET and decided to arrange the loop more efficiently to combat the heat from the GPU's, would this be more appropriate?
Can it be that restrictive? I can't find the dimensions of the copper pipe being used, but I am already using 3/8 tubing.
I'm going to have to draw up something without using the MOFSET, but looks like its going to be a bit harder.
TBH, it doesn't matter what block is first to go in the loop, the temps will be the same. I am speaking by experience, had my CPU first on my loop, then tried my GPU then CPU, even tried putting the radiators between the two blocks, no temp difference at all.
And I would suggest using hardline tubing, Hellfire toyz went in their build from traditional tube to acrylic tubing from primochill and they saw their flow rate doubled. probably because there are less pressure from the tubing.
And another thing, I believe that MOSFET/Chipset block from ASUS is aluminium based not copper, and I believe mixing aluminum and copper blocks can be bad due to corrosion?
Loop order doesn't matter until your flow rate is very low, and at that point you should be fixing your flow rate. Pretty much the only thing worth considering is pumping high to start out so that gravity helps you with the rest of your loop.Ahh man... Why tell me this now.. lol
I have yet to see a MOSFET block that isn't extremely restrictive. They just aren't a good idea for a performance loop. The 3/8" tubing isn't terrible as most parts in the loop are already more restrictive (1/4" can be, but that's another story).Can it be that restrictive? I can't find the dimensions of the copper pipe being used, but I am already using 3/8 tubing.
They must have screwed up the traditional tubing installation, laminar flow is laminar flow.And I would suggest using hardline tubing, Hellfire toyz went in their build from traditional tube to acrylic tubing from primochill and they saw their flow rate doubled. probably because there are less pressure from the tubing.
