wengchiochan
- Jul 12, 2005
I have the following components, may experts here please give me advice on the best way to set these things up , thanks
Alphacool Nexxos XP cpu block
Alphacool Nexxos gpu x2
Alphacool Nexxos nb
Watercool Dual HDD block
DDC pump x2
Alphacool Nexxos radiator 12.3 (1pass) and 12.1 (2 pass) http://www.alphacool.de/upload//high/14111_1.jpg
5.25inch bay reservoir
http://www.alphacool.de/upload//high/15609_1.jpg
all the above components are G1/4, i am thinking of using 10mm ID tubing, i would like to use 3/8inch ID tubing (which is what i am using now) but it 12mm Quickfit dun seems to fit on the nexxos block
i actually have another ALphacool AP1500 pump http://www.alphacool.de/perl/shop.p...menu_id=2&prod_id=130&art_kz=131&art_id=13106
but i think its better off to use 2xDDC with these restrictive nexxos blocks, right? lastly, i have 2 extra reservoirs too, not sure if i shall run dual loop or just one loop and running the pumps in serial.
Alphacool Nexxos nb
DDC pump x2
