How to Set 8 threads in Prime95?
sfsilicon
I downloaded Version 25.9 of Prime95 for x86 and I'm trying to stress test my i7 930 @ 4 GHz. For some reason I can't set Prime to run 8 threads. Every time I try to enter 8 in the box which lists 4 for threads. I get an error message when I try to confirm the dialog. It says select a number between 1-4.
I double checked and have hyper threading on in the bios and I was able to set 8 threads in LinX and pass 20 runs. What am I doing wrong?
Prime95 runs fine with 4 threads and I'm seeing 100% utilization on each core.
Have you tried running 2 instances of Prime? It could be hard-coded, I guess.
It allows 8 threads on my i7-920, but that is with the x64 version.
Just downloaded and tested the 32-bit version... it allows me to use 8 threads as well.
What happens when you open up the task manager performance tab? Does it show 8 threads or only 4?
I agree... does Windows see 4 or 8 available threads? Could it be that you don't have HyperThreading enabled in BIOS?
I'm seeing 4 cores in the performance tab. Not 8 threads.
I'm pretty sure I had the hyper threading enabled in the bios. I guess I could try toggling the setting and see it makes a difference.
BTW, CPU-Z is showing 4 cores and 4 Threads? Is that correct? Should it be 4 cores and 8 threads.
yeah it should be. most likely thing is that HT got disabled in the bios.
adds a good 10c to temps though :(
Yup, if Task Manager only shows 4 graphs under "CPU Usage History" then I'd say HT is disabled.
Rechecked Bios and HT was enabled. I tried disabling it and TM and CPU-Z are still showing 4 cores 4 threads.
Is there a Vista parameter that forces a specific number of cores to be recognized? I'm using the same Vista install with my previous Q6600 and I might have forced something in Vista a long while back. Can't remember anymore.
Otherwise I have no idea why only 4 threads are being displayed? Faulty CPU? Old Bios?
I'm using a MSI X58 PRO-E with Bios version V8.6. I think MSI has 4 newer ones with V8.A being the latest.
Figured it out. HT was enabled in the Bios. Windows Vista has a setting where you can set the number of processors. Coming from a Q6600 I had set this to 4. Follow the below if you run into the same problem.
Using msconfig, navigate to Boot > Advanced Settings and make sure Number of Processors is unchecked.
Thanks for everyones help!
