I have no idea what is the best way to run case fans?
I only have 1 exhaust fan and no inlet fan.I need to do womething since I am getting a hd4850 and my case will be cooking.
My case is a stock gateway case so I dont have alot of room inside.
I have 1 80mm fan under the psu and it is a exhaust.I have room for a 80mm or a 120 mm under the HD cage.I will have to cut the hd cage to fit a 120mm in there but it isn't a problem since I only have 1 hard drive inside of the cage.
The only thing I can think of is to place a 120mm in front on the bottom pulling air in from outside the case,a 120mm on the hd cage facing the rear pushing the air towards the exhaust..A 120mm in the bottom under the hd4850 as a exhaust, I will have to take out the pci e expansion slots and my 80mm under the psu at the upper part of the case as a exhaust.
Here is a pic of the inside of my case
http://support.gateway.com/s/PC/R/1009603/1009603mv.shtml
http://support.gateway.com/s/CASES/GERSHWIN/3507057Riv.shtml
I am kinda stumped at the moment and need some help please guys help me out.I dont have the cash to buy a new case but I can swing the fans right now so I can install them all when I hook up my hd4850.My 8800gt kept this case so toasty I had to keep the case side off and I dont like doing that since I have a 3year old daughter and she gets into everything
