how to remove search assistant
I tried by using adaware (the new one) spybot and spybouncer. Hijackthis removes the entry but it keeps on coming back. I tried also by removing all the references in the registry. I must remove this parasite
thats weird that spybot didn't help, did it even detect it? i've never had a problem removing spyware off of friends computers with spybot, even those tough ones that load on boot, spybot can scan on boot, i would suggest doing that so it can find and terminate the little bugger before it starts running. Also, if that doesn't work, you could always switch to Firefox :) (www.mozilla.org). :D
Try webroot spysweeper. It can often catch things that Adaware and Spybot miss.
I tend to use Adaware, Spybot, and Spysweeper to clean off malware. They often miss things by themselves, but using the three one after the other will fix almost anything.
