how to remove bonjour
antok86
i read that bonjour is useless/spyware that photoshop cs3 installs. if thats correct how do i remove it? i tried the tips from google but i cant seem to remove it from the cmd prompt. im using vista x64. thanks
i would also like to know this. this little useless app is pissing me off. im afraid to simply delete its folder in program files. i use vista firewall control so i disable any connections it tries to make but still. knowing its there sucks :p
From the Adobe website:
Adobe said:
To remove Bonjour:
1. Open a Windows command prompt and type the following command:
"C:\Program Files\Bonjour\mDNSResponder.exe -remove"
2. Navigate to the following folder in Windows Explorer: C:\Program Files\Bonjour
3. Rename the mdnsNSP.dll file in that folder to mdnsNSP.old
4. Restart your computer
5. Delete the the Program Files\Bonjour folder
hmm..
do i put program files C:\Program Files (x86)\Bonjour
or C:\Program Files\Bonjour damn..i think im missing something
i cant get it off..
Interesting, I use PS CS3, just looked and I have the bonjour folder in program files and such, but I have never really seen it pop up, in my system tray, or anything really.
Didnt know it existed until I saw this thread.
So whats so bad or annoying about it?
