How to reduce interference noise?
botw
I get a high pitched squeeling/hissing noise in my front headphone jack which is conntected to a Xonar DG (replacing an x-fi gamer that was producing all kinds of problems). Speakers connected to the rear ports don't have the problem. I assume my internal connections are picking up EM interference of some sort. Anyone know of a fix for this - or do I have to live with annoying background squeal in my headphones?
try connecting the front panel connector from the sound card to a different front audio port on a different computer case
You can get EMI shielding plastics and construct a bit of a barricade. Easier way would be to route your cabling so it avoids as much as possible (pretty much anything in the case can cause EMI).
Are you using a mini to mini connector, or are you connecting to the front-panel pins on the sound card (honestly don't know if that card even has them).
The easiest solution would be to just get a male to female 1/8" extension cable ($5-15 depending where you go) and run you headphones from the back of your PC. Also it is possible that your internal cable is just either weak or worn and replacing it would do wonders.
I get the same crap on my work laptop (Dell E6410), a nice mechanical whine behind all my audio, you're spot on in that it's EMI
The internal HD Audio is plugged in to the pins on the card. I'd plug in to the rear but it's not easily accessible and I only use the phones when I am playing games.
I guess I'll see if there any EMI shielding/cable wraps that can improve it...
