There are tools to do the job. The first set of tabs from the back is to hold the insulation. The second set of tabs holds the wire. I always crimp in that order. You can get the ratcheting kind of tool for $30, and it is well worth it, but the cheap crimpers from Radio shack can be made to work.cheezies said:How are these metal pins applied to a wire? Using a special tool? How should the wire be stripped before applying one of these?
unterhausen said:There are tools to do the job. The first set of tabs from the back is to hold the insulation. The second set of tabs holds the wire. I always crimp in that order. You can get the ratcheting kind of tool for $30, and it is well worth it, but the cheap crimpers from Radio shack can be made to work.
unterhausen said:This should work. I don' t have one, never delt with this company, but they seem to be mentioned here a lot. And a tool like this is going to cost a lot more than $30 from most places.
Yes the connectors are the same. It's a pain to get those pins out, even with the right tool.cheezies said:Will this tool remove the pins on my 24 pin ATX connector? It's made for the 20 pin ATX connector ...
DaRkF0g said:If you are looking for a great crimping tool then you can get one here
I myself have one and it makes it SO easy to insall the molex pins.
SarverSystems said:DO NOT DO NOT DO NOT use pliers. Pliers will do nothing but flatten out the connector. Use the tool shown above.
Format _C: said:Will This Crimper work from radioshack on the ATX and drive pins or both? As I bought one a while ago to wire my bg micro vfd to a serial port
