How to pull rivets?
RobbSpeed
Hey guys,
Brand to the forums but have been building my own rigs for quite a while. Have never actually modded cases but want to get into it soon. I have a CM HAF 932 on order to be here in a few days. In the meanwhile, I have a Silverstone TJ09 that I want to paint.
What's the best way (tool) to pull rivets and then re-attach them after I'm finished.
Thanks in advance for any suggestions.
Rob
Take a drill bit that is slightly larger than the center hole of the rivet to drill them out. Then just buy new rivets and a rivet fastener to replace them
Drill them out and then use a rivet gun and new rivets to put it back together.
It is very simple
just like Blue Aqua said, and he told me!
