I always forced v-snyc off until I got an lcd...now i've found that it's better to leave it on by default for most games.k0n said:so is vsync something lcd users should turn off?
how do u do that?
thnks
Deetox said:Problem is if he enables vsync in Quake3 he won't be able to pull off some of the jumps in the game. Some of them actually require 125fps.
yes its in the control panel. you can leave the vsync on application controlled in the Nvidia control panel since most games allow you turn vsync on/off in the game menu. if you turn it on in the control panel it will force it on in every game.k0n said:n00b question: how do i turn on vsync to begin with? somewhere in control panel?
PKFGimpy said:If you're a competetive Quake 3 player, I honestly think you're going to have trouble with any LCD.
VSync will cause enough input lag that you will notice a sluggishness to your mouse movements, so you will probably want to leave it off.
If you can get your LCD to run at 75Hz it would likely help, but would not eliminate the problem.
That's about all you can do. Personally, if I ever go back to playing fast paced FPS games, I just temporarily swap my 24" LCD with my old 21" CRT. No LCD can come close to the 100+ Hz refresh of a CRT in a game like Q3.
