how to pin a folder to taskbark?
mobusta1
I want to pin D:\Downloads (2nd harddrive) folders which contains all my movies to the taskbar (superbar) in windows 7. However, whenever I try to do this it keeps pinning the library folder. Is there a way around this?
The pin menu is supposed to launch applications, not documents. Documents/Folders can be accessed through the Jump List. Right-Click on the Exporer Icon or drag it up. You can pin your Downloads folder to that list.
This ^
Just drag the folder onto your taskbar, it will be added Explorer's jumplist
