Hello to All:
I am a newbie with a Velocity Micro E2250. Although the Intel Q9450 2.66 Quad processor is advertised as being overclocked to 3.2, CPU-Z analysis indicates that it is running at the stock 2.66MHz. I entered the BIOS, attempting to boost the FSB from 333 to 400, but I cannot locate the location in the BIOS to make the change. The mobo won't permit any increase in the multiplier beyond 8. Many reports indicate that this system should easily handle 3.2 stable. The cores currently run no hotter than 25C under load, and it is liquid cooled so cooling shouldn't be a problem. Any help would be appreciated.
Not bad for $700.00
Thanks in advance!
Not bad for $700.00
Thanks in advance!
