Moddest Mouse
- Jul 19, 2006
im getting the asus p5w dh deluxe and i need new ram and im getting the e6400
can someone give me advice for overclocking and ram to choose.
1. i dont get the changes between RAM and CPU(why raise ram and cpu and not cpu or ram?) in the context of overclocking
2. in laymans what is latency and their importance, can you change latency in bios, is a low latency important
3. should i start off in small increments until i crash it or should i go big and work down
4. what is HTT
5. do you know of anyone that has deystroyed a cpu/m0b0/ram when overclockin?
6. what air cooler works best( whatever you use or the highest overclockers use)
also, would attaching to heat sinks to the CPU work if you had something touching the cpu(a small triangular heatsink) and on the side of the heatsink put normal cpu coolers???
4. what is HTT
