How to overclock my ram ?
brahim
I have 2 sticks of gskill ram. Whats the potential i can get out of oc this ram ? A Link to an online guide would be awesome =) And does anyone have this ram ? If so what did you get out of it ?
specs
Model
Brand G.SKILL
Model F2-6400CL5D-2GBNQ
Type 240-Pin DDR2 SDRAM
Tech Spec
Capacity 2GB (2 x 1GB)
Speed DDR2 800 (PC2 6400)
Cas Latency 5
Timing 5-5-5-15
Voltage 1.8V - 2.0V
Heat Spreader Yes
Manufacturer Warranty
Parts Lifetime limited
Labor Lifetime limited
Well, I will personally know tomorrow at least. It should overclock like most ram. You just need to worry about voltage, timings, 1t/2t, and fsb. There is not much to overclocking ram.
