Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
i have an antec sonata lying around and i want to install a front intake duct with a 120mm fan on it. problem is, this sonata didn't come with the optional front intake, so how can i mount it?
Either one of you ever used a jigsaw, or a dremel? Then you get this thing, a lot of people call it a drill. Then you do just that, you drill. Then you get a screw driver and screw in. Anything can fit, you just need a dremel or a jigsaw, and you'll be set.
