How to measure power used
NME2rules
How do I measure the amount of power a computer is using when on. I want to know how much my server is sucking down. I'm pretty certain that my server isn't using what the power supply is rated for, but I know so little about electricity. I have multimeter if needed but I'm still teaching myself to use it. Any help would be appreciated, thank you!
1) get a good digital multimeter from radio shack or somewhere.
2) get an amp meaasureing kit that lets you measure amperage without having to cut and splice a wire to go through your new multimeter.
3) measure your computer, your monitor, heck measure anything you want with it now its yours :) I had one... I miss it :(
I''ve got a Watt meter. Basically, you plug your PC into it and then you plug the meter into the wall and it shows the amount of watts you are using.
