If it isnt even working, then bets are that your provider is blocking it(especially at colleges) You will need to change the ports used to something else
Cowcaster88 said:Does the orginal Bittorrent software (from BitTorrent.com) all you to have a range of ports open? Or will I need to download BitTornado to be able to open ports and use it on campus?
What is the suggested campus open range?
DermicSavage said:The origional client does not allow you to define your own ports, and you do not open a port throught he client. Opening ports is done with your router or firewall.(which if your campus has a firewall on the entire system you cannot open the ports)
As for which ports you can use, it's entirely up to what is open at the campus. So ask a super geek on campus on that one.
The concern is not about being safe, it is about it actually working.Cowcaster88 said:But if I just have a wide enough range of ports won't I be safe?
