hey i have a ripped copy of windows 2000 on my harddrive and i want to know how i can make this a ISO File. it is a folder and i want to make it iso folder so i can install it on my computer.
You are trying to backup your copy of Win2K correct?
You want to use a program like Nero and copy the disc to you hardrive as an image and you can then back it up to a cd from there.
What do you want explained. Stick CD in drive. Open UltraISO, choose Make ISO. UltraISO will let you make an ISO out of the files on your hard drive, but it will not be bootable. I don't mean that to sound like an ass, but I'm not understanding what your asking. If you take a look at UltraISO, you'll see you don't need any help...it's very simple.
ok since i want to boot from this cd, will this work if
i download the floppy disk setup thing and create 4 bootup disks and then use those floppydisk to install the os?
