how to make good raid 0 with 4 disk ?
What kind of drives are you using? That doesn't look bad to me. I have 2 Samsung spinpoint F 500GB drives in RAID 0 and I get sequential reads minimum 130 maximum 150 using HD tune.
i have 3 disk wd3200aaks and 1 disk wd2500ks
why i get with 4 disk less speed from 2 disk ?
why i get with 2 disk only 8.5 ms ? and with 4 disk 9.5 ms ?
FWIW a four drive SSD RAID 0 array was slower than three for me. Did you try the (3) 3200's - more is not always better.
Did you pull the jumper on your drives? It could be limiting you.. Also, Mixing drives on a RAID array might explain why four is slower than three.
so the fast that i can go is 200MBps ?
AND IF I HAVE SSD I CAN GO TO 500MBPS ?
http://www.ocztechnology.com/products/flash_drives/ocz_core_series_v2_sata_ii_2_5-ssd
In the best case scenairo you're not going to go 500 MBPS with four of those SSDs, you would have to go with the Vertex's and even then if your controller doesn't support it the your array will not be any faster than what you are seeing now.
1. i don't have jumper on drives .
2. in the book
RAID 0 OR RAID 1 CONFIGURATION REQUIRES AT LEAST TWO HARD DRIVES .
IF MORETHEN TWO HARD DRIVES ARE TO BE USED THE TOTAL NUMBER OF HARD DRIVES MUST BE AN EVEN NUMBER
THIS mean 2 or 4 disk ???
or i can 3 disk ?
2. in the book
or i can 3 disk ?
If that's what your manual says then that's what you got. It won't hurt anything to try 3....
Here's an HD tune of a guy running a pair of 30 GB vertexes on your south bridge. As you can see he's not breaking any records either.
attachment.php
AMDs on-board RAID controllers have never been known for being robust. At a pair of disks you are, just about, maxing it out from what I have seen.
