i have try different way like change the jumper on to the dvd drive, unplug the ide drive and install sata drive and vista will not load the installation.
ok I think the problem is this.....when you have multiple drives, motherboards/BIOS like to boot in this order, IDE0 master, IDE0 slave, IDE1 master, IDE1 slave, Sata1, Sata 2, etc etc etc..... after you install vista on the sata, and plug the pata in your board might try to boot off the IDE drive which has nothing on the MBR..... you may have to go into your bios and change the hard drive boot order or the booting hard drive. Operating systems take this behavior into account ......
also you should be able to install on the sata drive with the sata and pata drive installed, but vista might say that the pata drive is the c drive .....
